20 years agouclinux support for stratix II ep2s60 board
I have a stratix II ep2s60 board,where can I get the uclinux supporting for the Altera Nios II 2s60 Development board? Currently,The Microtronix Nios II Linux Distribution v1.4 don't support fo...
20 years agoHello!
You found Nios IDE II on ftp://ftp.altera.com/outgoing/release/ (ftp://ftp.altera.com/outgoing/release/) The ZIP file called nios_II_51_release.zip. The problem you reported could be caused by some incompatibility. To avoid problems like this I recommend to deinstall all old 5.0 stuff and also Linux 1.4. After this delete all diretories which are related to this stuff. Before you do all safe your projects. After you install the new Nios IDE 5.1, Quartus 5.1, Megacore IP Library 5.1, Linux 1.4, rebuild your project and try again. Bye, Lothar.
