20 years agouclinux support for stratix II ep2s60 board
I have a stratix II ep2s60 board,where can I get the uclinux supporting for the Altera Nios II 2s60 Development board? Currently,The Microtronix Nios II Linux Distribution v1.4 don't support for the Altera Nios II 2s60 Development board.
Thanks.12 Replies
It does not matter which chip you use in uclinux. Just choose anything from the supported dev board lists.
The only hardware dependancy is in the hwselect perl script, which matchs modules class, and generate header file nios2_system.h. - Altera_Forum
hippo,Thank you very much for your help.
I have another question about jtag id.My board is stratix II ep2s60.when I upload some examples supporting for stratix II ep2s60 board,it's successful.But when I upload the examples supporting for stratix II ep2s60ES,the error appears.the error is: Error: Can't configure device. Expected JTAG ID code 0x020930DD for device 1, but found JTAG ID code 0x120930DD. what's the problem,is there some configuration ralating with the jtag id?I'm very confused.who can help me ?Thanks. - Altera_Forum
Sorry, you should ask support from altera on this.
Other have similar problem. - Altera_Forum
for the jtag id problem.
you should change the device to es part, and recompile the hardware, as point out by slacker, http://forum.niosforum.com/forum/index.php?showtopic=3111 (http://forum.niosforum.com/forum/index.php?showtopic=3111) - Altera_Forum
thank you ,hippo.
which nios II version do you use?does it support stratix II ep2s60 board? - Altera_Forum
you should use qii v5.1 and nios2 v5.1.
Is nios2 v5.1 beta version?
No, v5.1 is official released now.
please check nios 5.1, there are two dir for 60 and 60es.
where can I download the official nios2 v5.1?
I have download a beta nios2 v5.1,when I choose the std_2s60.ptf to download the kernel to the board,the error appears. the error is : Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x021108C8: FAIL ID value does not match: read 0xFFFFFFFF; expected 0x079D820C Timestamp value does not match: image on board is older than expected Read timestamp 0:59:59 1970/01/01; expected 5:21:22 2005/10/21 Leaving target processor paused what is the cause?Is there something about configuration about nios2 or else?
