16 years agouClinux question
Hello, i just started to work with uClinux on an altera eval board. I have a question regarding uClinux. Does uClinux when running on a nios system have it's own compiler built-in? ...
16 years agouClinux running on board doesn't have GCC included in. Applications must be cross-compiled on a host Linux machine using Nios II binary tools (same used to compile kernel).
These are the precompiled tools. http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2 (http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2) So, your application can be added to your system in two ways: * Adding application during kernel compilation. * Adding the compiled application to your uClinux file-sytem through a storage device (USB pendrive, SD card) or a Network filesystem.
