16 years agouClinux question
i just started to work with uClinux on an altera eval board. I have a question regarding uClinux. Does uClinux when running on a nios system have it's own compiler built-in? Particularly what compiler do application on uclinux use? I,m a just a beginner and would like to learn this. Roman3 Replies
uClinux running on board doesn't have GCC included in. Applications must be cross-compiled on a host Linux machine using Nios II binary tools (same used to compile kernel).
These are the precompiled tools. http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2 (http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2) So, your application can be added to your system in two ways: * Adding application during kernel compilation. * Adding the compiled application to your uClinux file-sytem through a storage device (USB pendrive, SD card) or a Network filesystem. - Altera_Forum
I suppose it is somehow possible to ccross-compile the gcc compiler to have it run on the NIOS itself, such as there is a Debian Linux distribution that runs on ARM and can d/l additional packets in source code and compile and install them.
But I don't think anybody would bother to do that for a deeply embedded arch like NIOS, as it does not make much sense. -Michael - Altera_Forum
--- Quote Start --- I suppose it is somehow possible to ccross-compile the gcc compiler to have it run on the NIOS itself, such as there is a Debian Linux distribution that runs on ARM and can d/l additional packets in source code and compile and install them. t I don't think anybody would bother to do that for a deeply embedded arch like NIOS, as it does not make much sense. --- Quote End --- For embedded systems, to have their own self-compiler means the War of Independence for PC Imperial.:D But to get the true independence, we must obtain a Thoroughbred gcc. This means to rebuild the 'nios2gcc' on Nios system....:p Kazu
