21 years agouclinux project build ***errors
Hi, I am new to the uClinux. As per the linux Quick start guide.pdf file I completed doing the project succesfully, but I am facing the problem while doing the same again......with different pr...
21 years agoCheck you ACLs. I found that if I had restrictive security on the disk, cygwin could not execute the scripts of which there are a number of them. If you allow "Everyone" R/W/E access, that may fix your problem.
