21 years agouclinux project build ***errors
Hi, I am new to the uClinux. As per the linux Quick start guide.pdf file I completed doing the project succesfully, but I am facing the problem while doing the same again......with different pr...
21 years agoDear ken wong,
thanking you for your reply, I am not able to rebuild the orginal kernel project also.....! Actually I used the hardware of full_featured in the examples folder and I build the kernel and filesystem succefully according to the quick start guide. After that I uploaded to the board.... still the kernel and respective software example working nicely in the board. Now I planned to create another project with the same hardware and I tried to build the kernel for that according the quick start guide. here I failed to do..... Then I opened the orginalproject i.e., the first one and tried for rebuild the kernel.....here also the same errors are repeated..... I am not getting what to do.... but the first kernel in the board it is still working nicely.... please help in this regard..... thanking you once again, Regds, raj
