21 years agouclinux project build ***errors
Hi, I am new to the uClinux. As per the linux Quick start guide.pdf file I completed doing the project succesfully, but I am facing the problem while doing the same again......with different pr...
21 years agoAre you still able to rebuild the original kernel project? If not, something in your environment might have changed.
If you can still build the original kernel project from the quick start guide, then what can you tell me about the hardware that you're building the kernel for? i.e. how much ram, flash, uarts, etc.
