13 years agouclinux PIO device driver interrupt handler not execute
Hi, Thanks in advance for any help I can get. I have a NIOS2 w/MMU running uClinux v3.7. It's a DE2-115 development kit with Cyclone IV FPGA. I use the PIO megafunction to monitor input rising ...
13 years agoHi,
--- Quote Start --- 1) Enabling the PIO Core interrupt: Because my PIO base address is 0x00000060 on the a clock_crossing_bridge w/ base address of 0x08200000, my driver define base address is 0x082000060 (<-Is this correct?)# define ALTERA_PIO_BASE_ADDRESS 0x08200060# define ALTERA_OFFSET_DATA 0x00# define ALTERA_OFFSET_DIRECTION 0x01# define ALTERA_OFFSET_IRQ_MASK 0x02# define ALTERA_OFFSET_EDGE_CAPTURE 0x03 ... in probe function I have volatile int *base_addr = (int *) ALTERA_PIO_BASE_ADDRESS; ... *(base_addr + ALTERA_OFFSET_IRQ_MASK) = 0x01; //One input PIO from the SMA pin in the DE2-115, rising edge interrupt generator 2) __builtin_wrctl(3, 3); //irq2, write into ienable register (3) __builtin_wrctl(0, 1); //write 1 into status register (0) to enable PIE I got Kernel panic - not syncing: Oops Unable to handle kernel paging request at virtual address 08200000 ea = c70e418c, ra = c70e4178, cause =15 --- Quote End --- At first, please don't forget the existence of MMU. All cpu's memory accesses are filtered by it. So you must convert the virtual address 0x08200000 to I/O memory space one. According to the formal way, you should use the function 'ioremap' like
volatile int *base_addr = ioremap(ALTERA_PIO_BASE_ADDRESS, 16);
but for the convenience test, please try next code
volatile int *base_addr = (int *) (ALTERA_PIO_BASE_ADDRESS | 0xe0000000);
And because cpu's control registers are controlled by the kernel core, you don't need to tamper those like
There is also a formal way to set or reset these bits, so you should not touch control registers directly except the case you are sure what you do. Kazu
