13 years agouclinux PIO device driver interrupt handler not execute
Hi, Thanks in advance for any help I can get. I have a NIOS2 w/MMU running uClinux v3.7. It's a DE2-115 development kit with Cyclone IV FPGA. I use the PIO megafunction to monitor input rising ...
13 years agoI tried to do couple things in my uClinux device driver to enable the interrupt.
1) Enabling the PIO Core interrupt: Because my PIO base address is 0x00000060 on the a clock_crossing_bridge w/ base address of 0x08200000, my driver define base address is 0x082000060 (<-Is this correct?) # define ALTERA_PIO_BASE_ADDRESS 0x08200060 # define ALTERA_OFFSET_DATA 0x00 # define ALTERA_OFFSET_DIRECTION 0x01 # define ALTERA_OFFSET_IRQ_MASK 0x02 # define ALTERA_OFFSET_EDGE_CAPTURE 0x03 ... in probe function I have volatile int *base_addr = (int *) ALTERA_PIO_BASE_ADDRESS; ... *(base_addr + ALTERA_OFFSET_IRQ_MASK) = 0x01; //One input PIO from the SMA pin in the DE2-115, rising edge interrupt generator 2) __builtin_wrctl(3, 3); //irq2, write into ienable register (3) __builtin_wrctl(0, 1); //write 1 into status register (0) to enable PIE I got Kernel panic - not syncing: Oops Unable to handle kernel paging request at virtual address 08200000 ea = c70e418c, ra = c70e4178, cause =15 Did I write into or enable the wrong interrupt? my irq_mask is definite not turn on showing in the signaltapII. Any help is greatly appreciated. Yeung
