17 years agouClinux on StratixII
Hi all, I have designed my own NiosII cpu for a StratixII Dev. Kit. (http://www.altera.com/literature/man...tixii_2s60.pdf)
Can uClinux (procedure taken from nioswiki) run in my configuration (http://img269.imageshack.us/img269/7602/niosiiprocessor1.jpg) ? I've followed this (http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist) step by step, but it doesn't work. After the downloading of the kernel image in ram, nios2-terminal doesn't give me any output. I have some question : Why isn't u-boot necessary when I test my uClinux compiled kernel ? Have I made some mistake during the project with SOPC builder ( enable burst? fpu ? Tight Coupled Memory ?) ? Can someone help me ? P.S. I've trayed also to keep only the jtag uart and remove the uart (I've only USB-Blaster at the moment) but the result didn't change. P.P.S I've also tryed to view altera8.0\nios2eds\examples\vhdl\niosII_stratixI I_2s60_RoHS\full_featured, but the FPGA is wrong. The example project use EP2S60F672C3 but I have EP2S60F672C5. Is it same ?No RepliesBe the first to reply
