20 years agouClinux on DE2 board
hi all
I have run successfully uClinux on one custom board which has 2MB flash and 8MB sdram. I used nios2- ide .and i have generated romfs.bin amd vmlinux. I stored romfs at 0x00100000. It displayed following on console. ->///////////////////////////////////////////////////////////////// uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 7012k/8192k RAM, 0k/0k ROM (858k kernel code, 202k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80221080 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize custom map: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using custom development partition definition Creating 2 MTD partitions on "custom map": 0x00100000-0x00200000 : "romfs" 0x00000000-0x00100000 : "loader/kernel" VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 52k freed (0x8f2000 - 0x8fe000) /bin/hostname: not found expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 /bin/ifattach: not found /bin/inetd: not found /bin/boa: not found /etc/issue www.microtronix.com June 2005 Welcome to Linux on the Nios II (none) login: ->///////////////////////////////////////////////////////////////// now I am using DE2 board .it has 4MB flash and 8MB sdram. I have generated .ptf using SOPC builder with flash(4MB) ,sdram8MB, jtag_uart(irq-1) uart(irq-2)and timer (irq-0).nothing else .i used same kernel code as custom board. i changed only mtd partition.like static struct mtd_partition custom_partitions[] = { { .name = "romfs", .size = 0x200000, .offset = 0x200000, },{ .name = "loader/kernel", .size = 0x200000, .offset = 0x0, } }; and stored new romfs.bin at 0x00200000. but it hanged after some time. i can't able to understood what is worng with it.it gave following o/p: ->///////////////////////////////////////////////////////////////// uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 7116k/8192k RAM, 0k/0k ROM (823k kernel code, 133k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80484820 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize custom map: Found 2 x8 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using custom development partition definition Creating 2 MTD partitions on "custom map": 0x00200000-0x00400000 : "romfs" 0x00000000-0x00200000 : "loader/kernel" ->///////////////////////////////////////////////////////////////// plase help me. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif2 Replies
How is it done ?
Can u please explain the procedure to run uClinux on DE2 board which I use? DE2(Altera) has a Nios II processor and 4MB flash and 16MB SDRAM. I have Nios II IDE in Windows OS. I also installed QUARTUS II 7.0 ver Where should I install uClinux ? Please discuss the procedure for installation of uClinux . How do you generate romfs.bin file and vmlinux? - Altera_Forum
See the NIOSWIKI.
-Michael
