16 years agouClinux nommu does not detect PHY in SGMII mode
I have a 4sgx230 board and have been trying to get uClinux up on it. I have finally gotten it but I have a problem where the PHY is not detected. I am using TSE and the PHY is Marvel 88E1111. The boa...
16 years agoI guess the code is using the wrong set of registers for detecting the PHY, it works fine (tested with ping, dhcp, etc) if I use the second set. I changed the detection code:
from: for (phy_addr = 0x0; phy_addr < 0xFF; phy_addr++) { /* set the phy address to the mac map data */ writel(phy_addr, ATSE_MAC_REG_MDIO_ADDR_0); phy_id_1 = readl(ATSE_MAC_REG_MDIO_SPACE_0 + ATSE_PHY_ID_1_OFFSET); phy_id_2 = readl(ATSE_MAC_REG_MDIO_SPACE_0 + ATSE_PHY_ID_2_OFFSET); if (phy_id_1 != phy_id_2) { found_phy = 1; break; } To: for (phy_addr = 0x0; phy_addr < 0xFF; phy_addr++) { /* set the phy address to the mac map data */ writel(phy_addr, ATSE_MAC_REG_MDIO_ADDR_1); phy_id_1 = readl(ATSE_MAC_REG_MDIO_SPACE_1 + ATSE_PHY_ID_1_OFFSET); phy_id_2 = readl(ATSE_MAC_REG_MDIO_SPACE_1 + ATSE_PHY_ID_2_OFFSET); if (phy_id_1 != phy_id_2) { found_phy = 1; break; } Ill go through the TSE docs again and create the right patch so it works in all modes.
