21 years ago
uClinux mounting problem
Hi all,
I got problem when trying to mount a Linux PC to a local folder of Cyclone (/var) .
Here are the steps performed :
(the kit I'm using is cyclone 1c12 eval edition)
1) Log in uClinux on Cyclone
2) Setup an IP for the Cyclone : ifconfig eth0 192.168.1.20 netmask 255.255.255.0
3) Setup the IP for the Linux PC (Assuming : 192.168.1.19)
4) In Linux PC , Setup NFS shares by opening file /etc/exports (under ROOT) and add the following command :
/home/mymnt 192.168.1.20(rw)
5) Start NFS server : $ /etc/init.d/nfs start
6) Mount the Linux PC : mount –t –n nfs 192.168.1.19:/home/mymnt /var
After completing 6) , the following error occurred :
can't create lock file /etc/mtab~25: read-only file system (use -n flag to override)
I think the cause of the error is /etc folder (on cyclone) is READ-ONLY , so , uClinux cannot create mtab~25 on it. How can I "forward" the creation of mtab~25 to a writable folder such as /var , /usr ?
OneNet
    Hi OneNet,
    Add an empty file: /etc/mtab to your file system -- then try again -- this was all I needed.
    --Scott
    Hi Scott,
    As I mentioned , the folder /etc on Cycloneis READ-ONLY.
    (mtab~25 is created at runtime)
    Thank you so much,
    OneNet
    As the mount command told you: add the -n flag to your mount command. That way it doesn't try to write to the /etc/mtab file but mounts anyway.
    Hi Onenet,
    And as I mentioned, adding /etc/mtab to the filesystem worked for me. The problem
    I observed was related to locking /etc/mtab. The fact that the filesystem
    was readonly was irrelevant.
    --Scott
    Hi wqoossens ,
    I already used -n flag in the above commands.
    OneNet
    Hi Scott ,
    I added mtab and fstab to /etc of the Cyclone uClinux filesystem (I added fstab since if I I had added mtab ONLY , uClinux would have asked me for fstab)
    Here are the contents of both mtab and fstab :
    portmap:192.168.1.19
    lockd:192.168.1.19
    rquotad:192.168.1.19
    mountd:192.168.1.19
    statd:192.168.1.19
    where 192.168.1.19 is the IP of Linux PC
    I think these files set the connection TO the Linux PC we want to mount. (?????)
    Also , I have added a step :
    4a) In Linux PC , open /etc/hosts.allow as ROOT and add the following to the file :
    portmap:192.168.1.20
    lockd:192.168.1.20
    mountd:192.168.1.20
    statd:192.168.1.20
    where 192.168.1.20 is the Cyclone IP
    (the content of hosts.allow accepts the connection from the machines in the list)
    At step 6), run the command :
    mount 192.168.1.19:/home/mymnt /var
    The following error occurred :
    mount: rpc: port mapper failure - rpc: unable to receive
    About this error , I thaught that I "opened" connection between Linux PC (/etc/hosts.allow) and Cyclone (fstab , mtab). Do I have a lack of some step ?
    What do you think ?
    OneNet
    Hi Onenet,
    > By the way , do you know how to bring in the portmapper from the uCLinux CVS
    Use CVS to checkout the portmap code from the CVS repository.
    --Scott
