13 years agouClinux MMU, DEO Nano
Hello, We wish to install uClinux MMU on a DE0 Nano. After loading during decompilation on the DE0 Nano uClinux (nios2-teminal) we are faced with a crash "calibrating delay loop" Do you know ...
13 years agoHi,
At first, please check whether the timer interruption is working or not. The 'calibrate_delay' routine needs the increase of 'jiffies' as follows.
void __cpuinit calibrate_delay(void)
unsigned long ticks, loopbit;
int lps_precision = LPS_PREC;
if (preset_lpj) {
loops_per_jiffy = preset_lpj;
printk(KERN_INFO
"Calibrating delay loop (skipped) preset value.. ");
} else if ((smp_processor_id() == 0) && lpj_fine) {
loops_per_jiffy = lpj_fine;
printk(KERN_INFO
"Calibrating delay loop (skipped), "
"value calculated using timer frequency.. ");
} else if ((loops_per_jiffy = calibrate_delay_direct()) != 0) {
printk(KERN_INFO
"Calibrating delay using timer specific routine.. ");
} else {
loops_per_jiffy = (1<<12);
printk(KERN_INFO "Calibrating delay loop... ");
while ((loops_per_jiffy <<= 1) != 0) {
/* wait for "start of" clock tick */
ticks = jiffies;
while (ticks == jiffies)
/* nothing */;
/* Go .. */
ticks = jiffies;
__delay(loops_per_jiffy);
ticks = jiffies - ticks;
if (ticks)
break;
* Do a binary approximation to get loops_per_jiffy set to
* equal one clock (up to lps_precision bits)
loops_per_jiffy >>= 1;
loopbit = loops_per_jiffy;
while (lps_precision-- && (loopbit >>= 1)) {
loops_per_jiffy |= loopbit;
ticks = jiffies;
/* nothing */;
ticks = jiffies;
if (jiffies != ticks) /* longer than 1 tick */
loops_per_jiffy &= ~loopbit;
printk(KERN_CONT "%lu.%02lu BogoMIPS (lpj=%lu)\n",
loops_per_jiffy/(500000/HZ),
(loops_per_jiffy/(5000/HZ)) % 100, loops_per_jiffy);
} Kazu
