uClinux MMC SPI Driver
Just to let everyone know, an MMC SPI Driver for Alteras SPI Core (modified) is in the works.. currently, cards can be recognized, read/write, and even partitioned.. but some bugs are being worked out. If anyone is interested in an early release, let me know....
--- Quote Start --- originally posted by hippo@Apr 4 2006, 07:49 PM i am working on it , right now. still cleaning from 2.6.11 to 2.6.12 .<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14030)
--- quote end ---
--- Quote End --- cool - you can post a diff patch for each stage you go and I'll quickly test it out for you on my hardware. It would be nice if kernel.org had a SVN repo; then I could at least tell when the MMC layer changed!
Sure , I will send you the results for early testing.
<div class='quotetop'>QUOTE </div> --- Quote Start --- It would be nice if kernel.org had a SVN repo; then I could at least tell when the MMC layer changed![/b] --- Quote End --- The kernel.org use "git" for version control. But I didn't try it yet. - Altera_Forum
J,
I am still working on 2.6.12 . I am checking them again other arch, to find out the problem in nios2 kernel. Will let you know when I have some found. - Altera_Forum
It is strange.
when I set ddr sdram size from 64M to 8M, the page allocation failure did not happen. is it hardware issue? I will focus on this problem, and will not be available for others. sorry. - Altera_Forum
--- Quote Start --- originally posted by hippo@Apr 5 2006, 09:21 PM it is strange.when i set ddr sdram size from 64m to 8m, the page allocation failure did not happen.
i will focus on this problem, and will not be available for others. sorry.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14082)
--- quote end ---
--- Quote End --- Hey hippo,l I'm using a 32M DDR chip; that's really weird though. So you think it's a problem with the DDR core itself, maybel ocking up the avalon bus? <div class='quotetop'>QUOTE </div> --- Quote Start --- I will focus on this problem, and will not be available for others. sorry.[/b] --- Quote End --- I'm sorry, what do you mean by this?
I am using ddr sdram of 64M chip (x16) . I changed the ddr size to 8M in ptf for hwselect, and did not change the sof. I will do more testing on this, eg 16M 32M.
Please try out on yours. I mean, I will not have time to help others. I have to resolve this issue first. - Altera_Forum
ok, i understand; I will try this out to confirm, and I will have more time tomorrow to investigate. I will get bak to you shortly though.
16M is OK.
I just found there is ddr core update 3.3.1 . I got qii and nios2 v6.0 beta , too. I will try out right now. - Altera_Forum
I am already using 3.3.1 (it's been out for some time) - QII 5.1 sp2 and NII 5.1 sp1
Do you have boards that use sdram instead of ddr?
