20 years agouClinux MMC SPI Driver
Just to let everyone know, an MMC SPI Driver for Alteras SPI Core (modified) is in the works.. currently, cards can be recognized, read/write, and even partitioned.. but some bugs are being worked ou...
20 years agoWhen I change the ptf of a working board from 128M to 64M, then the test failed.
Just like what it was on the failed 64M board. I am learning more kernel debug. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif <div class='quotetop'>QUOTE </div> --- Quote Start --- # df Filesystem 1k-blocks Used Available Use% Mounted on /dev/hda1 503736 96 503640 0% /mnt# # dd count=800000 bs=512 if=/dev/zero of=/mnt/z2 800000+0 records in 800000+0 records out# # df df: page allocation failure. order:8, mode:0xd0 Stack from 01f37d98:<0> <0> 00000008<0> 000346e8<0> 00000000<0> 00000000<0> 00000000<0> 00000010<0> 00000001<0> 000000d0<0> <0> 000000d0<0> 001e01ec<0> 00000000<0> 001e01e0<0> 001df860<0> ffffe000<0> 03af8e00<0> 000385d0<0> <0> 00000010<0> 00000002<0> 00000000<0> 000a2098<0> 001f8920<0> 00000000<0> 00000077<0> 0039a080<0> <0> 00000001<0> 03af8e00<0> 00038174<0> 00000004<0> 0003f240<0> 00000000<0> 00000004<0> 002518c8<0> <0> 00251880<0> 00000007<0> 000681b8<0> ffffe000<0> 00000004<0> 00018c88<0> 00000001<0> 00003ef8<0> <0> 00000000<0> 00021254<0> 03af8e00<0> 000771e8<0> 00000002<0> 00000000<0> 01f37f20<0> 01f37f18<0> Call Trace:<0> <0> [<00032034>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<00003ef8>]<0> [<00000000>]<0> [<00000005>]<0> [<00000080>]<0> <0> [<00000000>]<0> [<00032210>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<00000014>]<0> [<0001d35c>]<0> [<000000d2>]<0> [<00000000>]<0> <0> [<000035ae>]<0> [<00060000>]<0> [<00080000>]<0> [<00090000>]<0> <0> [<00003e00>]<0> [<00000000>]<0> [<000a2098>]<0> [<00000000>]<0> <0> [<0000d6b8>]<0> [<00000080>]<0> [<00000058>]<0> [<00000000>]<0> <0> [<00076aa8>]<0> [<0005261c>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<00000000>]<0> [<00052924>]<0> [<00000000>]<0> [<00002310>]<0> <0> [<00000e98>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<000008d0>]<0> [<00000006>]<0> [<00000000>]<0> [<00000008>]<0> <0> [<00000018>]<0> [<00000000>]<0> [<0000000b>]<0> [<00000000>]<0> <0> [<00000000>]<0> [<00000001>]<0> [<00000000>]<0> Allocation of length 663704 from process 33 failed DMA per-cpu: cpu 0 hot: low 14, high 42, batch 7 cpu 0 cold: low 0, high 14, batch 7 Normal per-cpu: empty HighMem per-cpu: empty Free pages: 2884kB (0kB HighMem) Active:7923 inactive:5290 dirty:0 writeback:0 unstable:0 free:721 slab:1992 mapped:0 pagetables:0 DMA free:2884kB min:1024kB low:1280kB high:1536kB active:31692kB inactive:21160kB present:65536kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 HighMem free:0kB min:128kB low:160kB high:192kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 DMA: 35*4kB 59*8kB 16*16kB 1*32kB 1*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 0*2048kB 0*4096kB = 2884kB Normal: empty HighMem: empty Unable to allocate RAM for process text/data, errno 12 scheduling while atomic: df/0x00000001/33 Stack from 01f37f5c:<0> <0> 00000001<0> 000c6c24<0> 0000232c<0> 000e0440<0> 000e04a4<0> 03d85bd5<0[/b] --- Quote End ---
