20 years agouClinux MMC SPI Driver
Just to let everyone know, an MMC SPI Driver for Alteras SPI Core (modified) is in the works.. currently, cards can be recognized, read/write, and even partitioned.. but some bugs are being worked ou...
20 years ago --- Quote Start --- originally posted by jdhar@Apr 11 2006, 12:11 PM ok, and just so i know, how did you get these patches? are these a combination of the uclinux patches put out on top of code you have moved yourself (nios2nommu stuff for example - or is that in the uclinux tree?)? this is just so i know what you did and what was already done...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14222)
--- quote end ---
--- Quote End --- The uClinux uc0 patch is required for each kernel release. The first patch is just pull-out from the Microtronix's 1.4 release, the arch/nios2nommu, include/asm-nios2nommu, include/linux/elf.h, ide.h , uart and altcf. The second patch fix the compile errors, and got here by looking at other arch's patches, eg sh,h8300,mips,arm etc.
