20 years agouClinux MMC SPI Driver
Just to let everyone know, an MMC SPI Driver for Alteras SPI Core (modified) is in the works.. currently, cards can be recognized, read/write, and even partitioned.. but some bugs are being worked ou...
20 years agoThanks, I will try.
The code that we shall fix are mostly in the arch/nios2nommu/ kernel and mm dir . This is how I port to a new kernel. First, add the patch of linux-2.6.xxx-uc0 from uClinux.org (if one is available). I would copy arch/nios2nommu and include/asm-nios2nommu to a new kernel. Then try to compile with only the minimal config. I will move other drivers last. When there are problems, I used to check them with other arch , eg, sh and h8300, to find the problem. Maybe you can help to find out.
