14 years agouclinux Kernel error ?
Dear all.
I study a linux system on niosII I have many question. My status is : board : de2_115 version : uClinux nios2-linux-20100621. with mmu At first , my kernel messeage down here. as you know, my linux system kernel has 3 error. that is uart,jtaguart,flash,,,,, i don't know , Plz help me. ------------------------------------------------------------------------------------ Starting processor at address 0xC0000000 [root@localhost uClinux-dist]# nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [5-1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.34-00692-g5bc7853-dirty ([email protected]) (gcc version 4.1.2)# 6 Fri Jul 20 23:35:02 KST 2012 bootconsole [early0] enabled early_console initialized at 0xeb0428b0 Linux/Nios II-MMU init_bootmem_node(?,0x52d, 0x0, 0x8000) free_bootmem(0x52d000, 0x7ad3000) reserve_bootmem(0x52d000, 0x1000) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) We have 32768 pages of RAM Memory available: 124608k/5299k RAM, 0k/0k ROM (2033k kernel code, 3265k data) Hierarchical RCU implementation. NR_IRQS:32 Calibrating delay loop... 49.76 BogoMIPS (lpj=248832) Mount-cache hash table entries: 512 NET: Registered protocol family 16 init_BSP(): registering device resources altera_tse.0: failed to claim resource 2 ------------[ cut here ]------------ WARNING: at /home/ted/Alteras/nios2-linux/linux-2.6/drivers/base/core.c:131 device_release+0x80/0x84() Device 'physmap-flash.0' does not have a release() function, it is broken and must be fixed. Modules linked in: Stack from c7c16e5c: c7c01be0 c0010154 c7c2cd80 c0511b14 fffffff0 00000000 c00101d8 c04eb67c c7c16e88 00000000 c013caa4 c7c01be0 c050b044 c01144a0 c050b060 c0114448 00000003 c0115460 c050b044 c050b034 c0114374 c02105bc c02105bc c013b5bc c0140d74 c0140e80 00000001 c0140f04 00000000 00000000 c0200d50 deadbeef c0518230 c0200d7c c0000210 c00b0000 c0211288 c021142c c0211244 deadbeef 00000000 deadbeef c01fe5c8 c0509f6c c05240b0 00000a00 c0002294 00000000 Call Trace: [<c000be28>] [<c00021f8>] [<c0001074>] [<c0002288>] ---[ end trace 4eaa2a86a8e2da22 ]--- ------------[ cut here ]------------ WARNING: at /home/ted/Alteras/nios2-linux/linux-2.6/drivers/base/core.c:131 device_release+0x80/0x84() Device 'altera_uart.0' does not have a release() function, it is broken and must be fixed. Modules linked in: Stack from c7c16e5c: c7c01c60 c0010154 c7c2cde0 c0511b14 fffffff0 00000000 c00101d8 c04eb67c c7c16e88 00000000 c013caa4 c7c01c60 c050af94 c01144a0 c050afb0 c0114448 00000003 c0115460 c050af94 c050af84 c0114374 c02105b8 c02105b8 c013b5bc c0140d74 c0140e80 00000002 c0140f04 00000000 00000000 c0200d50 deadbeef c0518230 c0200d7c c0000210 c00b0000 c0211288 c021142c c0211244 deadbeef 00000000 deadbeef c01fe5c8 c0509f6c c05240b0 00000a00 c0002294 00000000 Call Trace: [<c000be28>] [<c00021f8>] [<c0001074>] [<c0002288>] ---[ end trace 4eaa2a86a8e2da23 ]--- ------------[ cut here ]------------ WARNING: at /home/ted/Alteras/nios2-linux/linux-2.6/drivers/base/core.c:131 device_release+0x80/0x84() Device 'jtag_uart.0' does not have a release() function, it is broken and must be fixed. Modules linked in: Stack from c7c16e5c: c7c01ce0 c0010154 c7c2ce40 c0511b14 fffffff0 00000000 c00101d8 c04eb67c c7c16e88 00000000 c013caa4 c7c01ce0 c050aee4 c01144a0 c050af00 c0114448 00000003 c0115460 c050aee4 c050aed4 c0114374 c02105b4 c02105b4 c013b5bc c0140d74 c0140e80 00000003 c0140f04 00000000 00000000 c0200d50 deadbeef c0518230 c0200d7c c0000210 c00b0000 c0211288 c021142c c0211244 deadbeef 00000000 deadbeef c01fe5c8 c0509f6c c05240b0 00000a00 c0002294 00000000 Call Trace: [<c000be28>] [<c00021f8>] [<c0001074>] [<c0002288>] ---[ end trace 4eaa2a86a8e2da24 ]--- bio: create slab <bio-0> at 0 Switching to clocksource timer NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 243 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mice: PS/2 mouse device common for all mice TCP cubic registered NET: Registered protocol family 17 turn off boot console early0No RepliesBe the first to reply
