16 years agouClinux in Nios II with MMU - Device Driver Kernel Panic
I'm developing a uClinux MMU kernel over a Nios II FPGA system and I'm having a lot of problemes when trying to run a custom device driver. I've managed to run a "Hello world" driver, but now I'm trying to run a "PIO port" driver with an Init function like:static int __init Init_LEDS(void){
if (!(request_mem_region((unsigned long)PIO_0_BASE, PIO_0_SPAN, "Leds")))
return -1;
if(register_chrdev( MAJOR_LED, MODULE_NAME, &Fops_Leds )){
printk("Error!!!!");
return -EIO;
printk("%s OK\n",MODULE_NAME);
Data = 1;
outb(Data,Pos_Leds_Mem);
return 0;
} This code prints the "printk" message but then it returns the following error in "outb": CPU 0 Unable to handle kernel paging request at virtual address 08001000, epc == c22210e0, ra == c22210d4
Kernel panic - not syncing: Oops I think it is probably due to the fact that I'm using a MMU system instead of a MMU-less one, but I've read other device drivers included in the uClinux MMU package and they also use the "outb" or "outl" function. Does anybody know how could I fix this problem, please? Or has anybody managed to create a character device driver for the MMU uClinux kernel? Thank you very much in advance. See you!2 Replies
Maybe Pos_Leds_Mem = 0x08001000. If this is the address of your LEDs, next code may help you, but I will not guarantee it.
If you want to make some driver for genuine Linux, I strongly recommend you to study the functionality of MMU and the meaning of virtual addresses. Kazuoutb(Data, ((unsigned long)Pos_Leds_Mem) | 0xe0000000); - Altera_Forum
Thank you very much for your reply! Yesterday I managed to fix the problem and, as you say, it was due to the virtual addresses mapping. The "outb" function is correct, but before this it is compulsory to make a "ioremap" call to remap the real address into virtual one (I found the "hrtimer.c" example in the Nios Wiki where something similar was used). Then, as any other device driver, "copy_to_user()" and "copy_from_user()" are needed to pass information between kernel and user space. Now, I am trying to make the device driver to read and write words instead of bytes and to use interrupts, because of my hardware requirements. I hope this to be easier hehehe By the way, I am having problems when trying to load the module with "modprobe"/"insmod". It works fine if I add it to the kernel, but when I make a "modprobe" the CPU stops running. I checked the apps config and everything is fine. I will keep on working on that!! See you!
