14 years agouClinux hangs at while booting
Hi all, I have a zImage that works fine on my development board (3c120 DSP KIT). I'm not using the device tree approach but the older one, at this point we have no enough time to switch to devi...
13 years agoHi again,
I've solved the problem related to Altera TSE driver. It was due to the addresses of the two DMA I put into the SoPC. It seems that, if we use uClinux with TSE, sgdma_rx and sgdma_tx have to be spaced of at least 0x400 because of memory allocation issues http://www.alteraforum.com/forum/showthread.php?t=27685 (http://www.alteraforum.com/forum/showthread.php?t=27685) look at davidsmoot's reply Marco
