20 years agouclinux for full_featured
Hi Hippo, As per suggestion, I install Fedora Core 5. It works fine and i am able to create image of uclinux for nios II/s (standard). thanks for your help. I need to create an imag...
20 years ago --- Quote Start --- originally posted by hippo@May 3 2006, 08:58 PM i have built a zimage for full_1s40.ptf without problem.
for the dual nios2 uclinux project, you can make two copy of the original ptf.
modified each one to have different sdram size and base, uart base, reset address, exception..etc.
eg, module sdram
original address_width=22, base_address=0x01000000,
become
cpu1, address_width=21, base_address=0x01000000,
cpu2, address_width=21, base_address=0x01800000,
so that you can build two kernel images.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15004)
--- quote end ---
--- Quote End --- Hello Hippo, I am able to build zImage of full_1s40.ptf But during boot-up period, it got hang on PID value. The boot sequence is below: ******************************** Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.6)# 4 Wed May 3 16:05:52 IST 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 128 (order: 7, 2048 bytes) ******************************** Kindly, acknowledge me, what is fault during building the zImage for full_1s40.ptf. thanks & regard, Goutam
