21 years agouClinux for Custom board
1. What to do when you have a custom board that isn't on the kernel config list?
2. The board has: 16MB flash, 1MB SRAM, JTAG_UART @25MHz, Is it possible to run uClinux? And then Add: DM9000A, I2C, LCD, UART, JTAG_UART, Is it enough memory to run uClinux? please give me some advice, thank you.3 Replies
1. Use a similar one existing in the kernel config list, or add your own.
2. You don't have enough memory if the 1M sram is all you have. - Altera_Forum
So could you give us the minimal memory of the minimal uClinux ( only the kernel, no other componets), and how to do when "make menuconfig"? Thank you
I've gotten the kernel to run on 4 Megs x 32 (16 MB), but you can't do much with it.
