20 years agouCLinux file system...
Hi. I'm using the Microtronix Product Starter Kit with the NIOS-II IDE and uCLinux 2.6. Followed the steps starting on p. 13 of "Nios II Linux Quickstart Guide" to create and build the ro...
20 years ago --- Quote Start --- originally posted by hippo@Dec 19 2005, 04:43 PM look at linux-2.6.x/documents/devices.txt for the list of devices numbers.
use "mknod" to add the node,
mknod /dev/sda b 8 0
mknod /dev/sda1 b 8 1
and add to your init script,
mount -t usbfs none /proc/bus/usb
by the way, i would recommand building toolschain and developing on linux.
it would be much faster and less trouble.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11649)
--- quote end ---
--- Quote End --- Thank you, hippo. I tried your suggestion, and I get: "mknod: cannot make device /dev/sda", and, "mknod: cannot make device /dev/sda1". I'm new to Linux, unfortunately, but that's temporary. What do you suppose is happening here? Thanks again.
