21 years agouClinux feature support
Small question to NIOS2 uClinux users...
Has anyone used, nios2 uClinux with initrd support or RAMDisk ? Is anyone using any alternative other than romfs.img support mounted as readonly-root fs supplied as part of evalutaion kit ? Any alternative suggestions to mount and use a r/w filesystem will be deeply appreciated.1 Reply
Here is something you can try if you want to use a RAMdisk as the root fs:
Busybox comes with the chroot and pivot_root utilities, so you can use those to change the root fs to your RAMdisk once it is mounted. What you have to do is create a ramdisk image that has all the files and directories needed for your root filesystem. A ramdisk image can be created on a Linux host as shown:
The holes utility compresses the ramdisk image, here is the source for that utility:dd if=/dev/zero of=/dev/ram0 bs=1k count=2048 /sbin/mke2fs -s0 -vm0 /dev/ram0 2048 /sbin/tune2fs -i 0 /dev/ram0 mount /dev/ram0 /mnt rmdir /mnt/lost+found { populate your filesystem here} umount /mnt dd if=/dev/ram0 of=ramfs2048 bs=1k count=2048 ./holes ramfs2048 > ramfs2048.img
Once you have your ramdisk image, you can include it in your Microtronix Nios II Filesystem Project. You can then edit your /etc/inittab and /etc/init.d/rcS files to use pivot_root and chroot on start up to switch the root filesystem to a RAMdisk during start up. For example, your /etc/inittab file might look something like this:/* make a file with holes */ # include <unistd.h># include <stdlib.h># include <stdio.h># include <sys/types.h># include <sys/stat.h># include <fcntl.h> char buf; int main(int argc, char *argv) { int count; int pos; int zcount; int b; int len; int in = open(argv, O_RDONLY); len = lseek(in, 0, SEEK_END); fprintf(stderr, "TOTAL LEN=%x", len); lseek(in, 0, SEEK_SET); len = htonl(len); write(1, &len, 4); fprintf(stderr, "\n", len); pos = zcount = count = 0; while(read(in, &buf, 1) > 0) { pos++; if (count || buf) { count++; if (buf == 0) zcount++; if ((zcount == 8) || (count == 2048)) { b = htonl(pos-count); write(1,&b,4); fprintf(stderr, "POS=%x:", pos-count, b); b = htonl(count); write(1,&b,4); fprintf(stderr, "LEN=%x", count, b); write(1,buf,count); fprintf(stderr, " --> DATA=%x\n", buf); count = zcount = 0; } } } if (count) { b = htonl(pos-count); write(1,&b,4); fprintf(stderr, "(%d)=%x\n", 4, b); b = htonl(count); write(1,&b,4); write(1,buf,count); fprintf(stderr, "(%d)=%x --> (%d)=%x\n", 4, b, count, buf); } }
And your /etc/init.d/rcS file could include something like this :::askfirst:-/bin/sh ::sysinit:/etc/init.d/rcS...# for pivot root /bin/expand /ramdisk.img /dev/ram0 /bin/mount -t ext2 /dev/ram0 /mnt/ide0 -n cd /mnt/ide0 mkdir old-root pivot_root . old-root exec chroot . sh <dev/console >dev/console 2>&1 umount /old-root ...
