19 years agouClinux-dist compilation
Hello! I have installed nios2 BinaryToolchain. Then I have downloaded uClinux-dist-20070130 and have applied uClinux-dist-20070130-nios2-02.diff.gz patch and "make vendor_hwselect" for my .ptf fi...
19 years agoYou must have SDRAM to run uClinux. But you still need a CFI flash to do hwselect, just add a dummy one if you don't.
Or, you may try the ptf file , only to validate the toolchain, /opt/altera6.1/nios2eds/examples/verilog/niosII_cycloneII_2c35/standard/std_2C35.ptf what is the message during vendor_hwselect?
