19 years agouClinux-dist compilation
Hello! I have installed nios2 BinaryToolchain. Then I have downloaded uClinux-dist-20070130 and have applied uClinux-dist-20070130-nios2-02.diff.gz patch and "make vendor_hwselect" for my .ptf fi...
19 years agoThank you, hippo. I reinstall uClinux-dist tree but compilation failed with the same error! :-(
What reasons can be? 1)Wrong .ptf ? Then, what vertion of Quartus I should use? Can I use only SDRAM in my project? 2)Wrong insallation of nios2gcc? I also use except for nios2gcc other gnu compilers on my PC. Need I in additional adjustments? Now try to reinstall Linux on my PC and recompile my project... Thanks!
