20 years agouClinux-dist added to buildroot guide
The uClinux-dist has a lots of apps ported to uClinux, such as BOA(httpd), dhcpd, net-snmap... etc. Now included in the buildroot guide, http://forum.niosforum.com/forum/index.php?showtopic=3174...
20 years ago --- Quote Start --- originally posted by jdhar@Feb 17 2006, 11:44 PM your problem is definitely lack of initramfs... check out the post, and make sure you generate your filesystem correctly, with the appropriate device nodes in /dev (you need to be root to do this)!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12772)
--- quote end ---
--- Quote End --- Hi Jdhar, I updated the initamfs config, add a text file ~/download/rootfs_list for the list of /dev nodes and the /init link, so that a root login is not required now.
