20 years agouClinux-dist added to buildroot guide
The uClinux-dist has a lots of apps ported to uClinux, such as BOA(httpd), dhcpd, net-snmap... etc. Now included in the buildroot guide, http://forum.niosforum.com/forum/index.php?showtopic=3174...
20 years agoYour problem is definitely lack of initramfs... check out the post, and make sure you generate your filesystem correctly, with the appropriate device nodes in /dev (you need to be root to do this)!
