19 years agouClinux-dist-20060803 update ver 22
ver 22. add DM9000A vendor driver dm9ks, with IP/TCP/UDP checksum offloading will speed up around 10%. add Altera VGA frame buffer driver altfb. fix microwin. wiki FrameBuffer. use zflat obje...
19 years ago --- Quote Start --- originally posted by bigboss25@Jan 5 Wonderful! i will try the torrent.
how did you built it?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20397)
--- quote end ---
--- Quote End --- For building gcc with C++ I've used instructions http://nioswiki.jot.com/wikihome (http://nioswiki.jot.com/wikihome) and I've made some changes in Makefiles (I don't remember all the changes because I've done quite some builds before I've got it working correctly for my DOS/OS2/WINDOWS ported application). I've also ported pure-ftpd-1.0.21 and fixed mtd-utils to run on NIOS2 target if some one is interested don't hesitate to contact me. If the azureus link doesn't work you can use torrent file which should work (tested). http://wired.homelinux.net/torrents/build_....tar.gz.torrent (http://wired.homelinux.net/torrents/build_nios2.tar.gz.torrent) here is my current romfs I am using. Pure-ftp server, ftp client, ntp, dhcp, wget, vi, msh are included. http://wired.homelinux.net/nios/romfs.tar.gz (http://wired.homelinux.net/nios/romfs.tar.gz) Uros
