19 years agouClinux-dist-20060803 update ver 22
ver 22. add DM9000A vendor driver dm9ks, with IP/TCP/UDP checksum offloading will speed up around 10%. add Altera VGA frame buffer driver altfb. fix microwin. wiki FrameBuffer. use zflat obje...
19 years ago --- Quote Start --- originally posted by hippo+jan 4 2007, 09:00 pm--><div class='quotetop'>quote (hippo @ jan 4 2007, 09:00 pm)</div>
--- quote start ---
<!--quotebegin-bigboss25@Jan 5 2007, 12:27 AM nice job http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/tongue.gif
do you think it is possible to use fltk gui library with uclinux?
regards.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20364)
--- quote end ---
--- Quote End --- Not ready yet. The FLTK uses C++. And I still have problems to run C++ with my tools. It seems Microtronix has a working C++ tools for uClinux, but I didn't have access to the sources, which must be GPL.! Maybe you can help to check with them. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20374)</div> [/b] --- Quote End --- I have build NIOS2 C++ compiler from build root and it works. I can share build version witch I am using for compiling my C++ application. I had few problems with some C++ functions relocation due to limitation of FLT format so I had to put some debug messages in kernel flt module to find out which functions caused incorrect relocation. I've created a torrent if you want to download it magnet:?xt=urn:btih:LLIFN5EYIAIHRP5RVAC5MASQ6GWN3SJW Uros
