21 years agouClinux .data segment in SDRAM?
For a number of reasons, I'd like to run my kernel in SRAM but allocate data memory (i.e. socket buffers) in SDRAM. This seems possible with a NIOS 'Hello World' application, or the like...
21 years agoHi Wentao,
I went back and started from scratch on this, and I got the kernel to use SDRAM as GFP_DMA. I can allocate a buffer using 'kmalloc' in SDRAM. However, I have since encountered a couple new problems: 1) I can't seem to kmalloc more than 4MB -- not sure if this is normal behavior or not. 2) I get Perror: Bad Address when I try to send an SDRAM buffer over a TCP socket, regardless of the size of the buffer. Googling for this perror I see that it's caused by an 'invalid address'. Thanks again, I think I'm getting close, Ryan
