21 years agouClinux .data segment in SDRAM?
For a number of reasons, I'd like to run my kernel in SRAM but allocate data memory (i.e. socket buffers) in SDRAM. This seems possible with a NIOS 'Hello World' application, or the like...
21 years agoHi Wentao,
I've been back and forth on this project and another, so sorry for no response last week. I've been through a number of permutations of mappings and kernel changes in attacking this problem, so I'll just post what I have now (and how it's failing) and hopefully you may have some suggestions. I had our board image remapped to eliminate the 'gap' between SDRAM and SRAM. So, now the map looks like this: 0x0-0x07ffffff -- 128MB of SDRAM 0x08000000-0x09000000 -- 16 MB of SRAM So, again, I'd like to run code in SRAM but allocate kernel memory in SDRAM. I edited paging_init to give all of SRAM to ZONE_DMA:zones_size = (0x08000000-PAGE_OFFSET) >> PAGE_SHIFT; and I changed ZONE_NORMAL accordingly: zones_size =(end_mem-0x08000000) >> PAGE_SHIFT; (note: here end_mem is 0x09000000) Then I edited page.h to# define PAGE_OFFSET as 0. These changes build fine and boot on the new image. However, when I try: char * str = kmalloc(2048,GFP_DMA) ...I get the following 'page allocation failure': swapper: page allocation failure. order:0, mode:0x1
Stack from 08327eb8:<0>
<0> 00000000<0> 0802dc14<0> 00000000<0> 00000000<0> 00000001<0> 00000003<0> 00000000<0> 00000001<0>
<0> 00000000<0> 0817b8ec<0> 0817b8e0<0> 082f2060<0> 0817b8e0<0> deadbeef<0> 0802dc44<0> 08031a54<0>
<0> 00000000<0> 08032300<0> deadbeef<0> deadbeef<0> deadbeef<0> deadbeef<0> fffffc18<0> 00000001<0>
<0> 00000001<0> 00000001<0> 08031fb8<0> 08c0e000<0> 08169f90<0> deadbeef<0> fffffc18<0> 00000001<0>
<0> 00000000<0> 0816c608<0> 081698f8<0> 0816c30c<0> 0816c8d0<0> 00000001<0> 00000001<0> 08169a0c<0>
<0> 00000000<0> 0816c890<0> 08000274<0> deadbeef<0> deadbeef<0> deadbeef<0> 081756c0<0> 080044c4<0>
Call Trace:<0>
<0> <0> <0> <0> <0>
<0> <0> <0> Just wondering if there is anything you could suggest I do. My options are fairly open (that is, I can remap SDRAM somewhere else if necessary). Let me know if anything needs clarified. Thanks in advance, Ryan Quantapoint, Inc.
