20 years agouclinux builid error
Dear all,
This is the error file attached in the website,pls see iit,help me ,thx!4 Replies
dear hippo,
According to you,I download the builld.zip ,uClinux-dist-20051110,and nios2linux-1.4.zip, then execute the ./build this is the error information in the terminal : tar: buildroot/package/bash/bash31-009: Cannot open: 没有那个文件或目录 tar: buildroot/package/bash/Config.in: Cannot open: 没有那个文件或目录 tar: buildroot/package/Config.in: Cannot open: 没有那个文件或目录 tar: buildroot/package/Makefile.in: Cannot open: 没有那个文件或目录 tar: buildroot/.defconfig: Cannot open: 没有那个文件或目录 tar: buildroot/Config.in: Cannot open: 没有那个文件或目录 tar: buildroot/Makefile: Cannot open: 没有那个文件或目录 tar: Error exit delayed from previous errors ./build: line 40: cd: /home/fzh2004/buildroot: 没有那个文件或目录 can't find file to patch at input line 5 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |Index: toolchain/uClibc/uClibc.config |=================================================================== |--- toolchain/uClibc/uClibc.config (revision 14578) |+++ toolchain/uClibc/uClibc.config (working copy) -------------------------- File to patch: thanks! - Altera_Forum
But I don't recommend the buildroot approach to newbie now.
Please go to the nios wiki, http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux) try out the prebuilt zImge if you have altera nios dev board, install binary toolchain, and follow the uClinux-dist to build kernel and apps. - Altera_Forum
THANKS
I WANT TO DO ACCORDING TO YOU,BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busybox-20060320.tar.bz2,uClibc-20060320.tar.bz2 AND buildroot-20060320.tar.bz2 COULD YOU HELP HOW TO MODIFY THE BUID FILE: # !/bin/bash# rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source cd ~/download mkdir mx140 cd mx140# convert the crlf with unzip -a echo "prepare kernel source" unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~ cd ~/linux-2.6.x patch -p0 <~/download/kernel.diff cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains mkdir ~/apps cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps cd ~/apps patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source cd ~/download echo "prepare uClinux-dist source" wget -N http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-20051110.tar.bz2) cd ~ tar jxf ~/download/uClinux-dist-20051110.tar.bz2 cd ~/uClinux-dist patch -p0 <~/download/uClinux-dist.diff touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab# download buildroot snapshot cd ~/download SNAPSHOT=20060320 rm -f buildroot-snapshot.tar.bz2 uClibc-snapshot.tar.bz2 busybox-snapshot.tar.bz2 # wget -N http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2 (http://buildroot.uclibc.org/downloads/snapshots/buildroot-$snapshot.tar.bz2) #wget -N http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2 (http://www.uclibc.org/downloads/snapshots/uclibc-$snapshot.tar.bz2) #wget -N http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2 (http://busybox.net/downloads/snapshots/busybox-$snapshot.tar.bz2) wget -N http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/buildroot-20060320.tar.bz2) wget -N http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2) wget -N http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2) ln -s buildroot-$SNAPSHOT.tar.bz2 buildroot-snapshot.tar.bz2 ln -s uClibc-$SNAPSHOT.tar.bz2 uClibc-snapshot.tar.bz2 ln -s busybox-$SNAPSHOT.tar.bz2 busybox-snapshot.tar.bz2 cd ~ tar jxf ~/download/buildroot-snapshot.tar.bz2 cd ~/buildroot ln -s ~/download dl# patches for configs, add elf2flt to busybox patch -p0 <~/download/buildroot.diff make oldconfig make# clean headers for uClinux-dist cd ~/buildroot/build_nios2/staging_dir/include/linux rm config.h autoconf.h touch config.h autoconf.h# prepare root fs rm -rf ~/rootfs mkdir ~/rootfs cp -a ~/buildroot/build_nios2/root/* ~/rootfs cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot cp ~/download/inittab etc - Altera_Forum
Please post your questions on the uClinux area, not here.
You will need more files for buildroot, and take more time. Please download the binary tools and rootfs from the nios wiki, and install them. Then use this script to prepare the sources, and you can compile the kernel. But I still recommand you follow the uClinux-dist approach as in the wiki.#!/bin/bash rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source cd ~/download mkdir mx140 cd mx140# convert the crlf with unzip -a echo "prepare kernel source" unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~ cd ~/linux-2.6.x patch -p0 <~/download/kernel.diff cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains mkdir ~/apps cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps cd ~/apps patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source cd ~/download echo "prepare uClinux-dist source" cd ~ tar jxf ~/download/uClinux-dist-20051110.tar.bz2 cd ~/uClinux-dist patch -p0 <~/download/uClinux-dist.diff touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab
