16 years agouClinux build questions
To start off, I'm just new to build uClinux environment, so been learning curve but getting there. I followed instructions: http://www.nioswiki.com/installnios2linux but what I noticed when ...
16 years agoOnce you have all the tools installed, the instructions to build uClinux without MMU are here: http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist
If you are using an MMU the instructions are here: http://www.nioswiki.com/linux You need to check "Customize Application/Library Settings" (or "Customize Vendor/User Settings" in some versions) in menuconfig to choose userland applications. You just do 'make' to build everything.
