22 years agouClinux boot up
I have created uClinux filesystem using the distribution downloaded from this forum. When I power up the nios2 board, the uClinux can't boot up untill I open nios2-terminal. What is the reason?
16 years agoWell, it used to be done by ticking an option in menuconfig. I haven't used the MMU "flavor" much, so I can't comment on whether this sort of thing is feasible in that flow.
http://www.nioswiki.com/index.php?title=operatingsystems/uclinux/uclinuxdist/linuxconfig I'm taking it that the option mentioned here is no longer available? Have you tried posting to the dev list? Good luck! -slacker
