16 years agouClinux boot routine
I'm just curious about the boot process of uClinux on my NIOSII board. I'm downloading the zImage over the NIOSII command shell: nios2-download -g What is the relation between the bootloader and the zImage file and whats with the -g parameter in the command? Would like to explain this part in my documentation and would appreciate if somebody could give some comments. Thanks again, Roman5 Replies
-g just says nios2-download to start the CPU after the download. If you omit -g, nios2-download will load the elf file in memory, but leave the CPU in a paused state.
--- Quote Start --- whats with the -g parameter in the command? --- Quote End --- nios2-download --help -Michael - Altera_Forum
Thx for replies.
So where is the zImage file stored when I'm downloading with this methode to the board? Roman - Altera_Forum
The elf file itself contains the address at which the data should be uploaded.
thanks a lot
