20 years agouClinux Boot problem
I am testing my own custom board with EP1C12Q240, Flash=16bit*4M, Sdram=32bit*2M. My system has NiosII/f Core, uart, jtag-uart, sdram, flash, epcs_controller, timer and some PIOs. I use U-Boot to boot uClinux of Microtronix 1.4. When I run bootm command to boot uClinux, there display <div class='quotetop'>QUOTE </div> --- Quote Start --- ==> bootm 0x50000 # # Booting image at 00050000 ... Image Name: Linux Kernel Image Image Type: Nios-II Linux Kernel Image (gzip compressed) Data Size: 458311 Bytes = 447.6 kB Load Address: 00800000 Entry Point: 00800000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Linux version 2.6.11-uc0 (LiangYi@ciitec-liangyi) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 1 Thu Feb 23 15:45:58 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 7016k/8192k RAM, 0k/0k ROM (850k kernel code, 206k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 NIOS serial driver version 0.0 ttyS0 (irq = 3) is a builtin NIOS UART io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Microtronix map: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Microtronix development partition definition Creating 2 MTD partitions on "Microtronix map": 0x00200000-0x00800000 : "romfs" 0x00000000-0x00200000 : "loader/kernel" VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 52k freed (0x8f0000 - 0x8fc000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 SIOCSIFADDR=-1: 9 SIOCGIFFLAGS = -1: Bad file descriptor (9) SIOCADDRT=-1: 9 Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket[/b] --- Quote End --- I do not know What is wrong? I use NiosII-IDE to generate vmlinux.bin and romfs.bin and do <div class='quotetop'>QUOTE </div> --- Quote Start --- $ gzip -9 vmlinux.bin $ mkimage -A nios2 -O linux -T kernel -C gzip -a 0x00800000 -e 0x00800000 -n 'Linux Kernel Image' -d vmlinux.bin.gz uImage.img $ bin2flash –flash=U5 –location=0x00050000 –input=uImage.img –output=uImage.flash $ nios2-flash-programmer –base=0x00800000 –input=uImage.flash –sof=<path to pgm sof> $ bin2flash --flash=U5 --location=0x00200000 --input=romfs.bin --output=romfs.flash $ nios2-flash-programmer –base=0x00800000 –input=romfs.flash –sof=<path to pgm sof>[/b] --- Quote End --- Then, run bootm and display above. Can someone help me? BTW, another question. When I use <div class='quotetop'>QUOTE </div> --- Quote Start --- $ mkimage -A nios2 -O linux -T filesystem -C none -a 0x00a00000 -e 0x00a00000 -n 'romfs' -d romfs.bin romfs.img $ bin2flash --flash=U5 --location=0x00200000 --input=romfs.img --output=romfs.flash $ nios2-flash-programmer –base=0x00800000 –input=romfs.flash –sof=<path to pgm sof>[/b] --- Quote End --- There display <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 7016k/8192k RAM, 0k/0k ROM (850k kernel code, 206k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 NIOS serial driver version 0.0 ttyS0 (irq = 3) is a builtin NIOS UART io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Microtronix map: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Microtronix development partition definition Creating 2 MTD partitions on "Microtronix map": 0x00200000-0x00800000 : "romfs" 0x00000000-0x00200000 : "loader/kernel" Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b] --- Quote End --- I do not know what different between these two method and which is correct for me and how to deal with the problem. Thank you, LiangYi11 Replies
Why do you want to use u-boot with IDE?
