20 years ago
uClinux Boot problem
I am testing my own custom board with EP1C12Q240, Flash=16bit*4M, Sdram=32bit*2M.
My system has NiosII/f Core, uart, jtag-uart, sdram, flash, epcs_controller, timer and some PIOs.
I use U-Boot to boot uClinux of Microtronix 1.4.
When I run bootm command to boot uClinux, there display
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
==> bootm 0x50000
# # Booting image at 00050000 ...
Image Name: Linux Kernel Image
Image Type: Nios-II Linux Kernel Image (gzip compressed)
Data Size: 458311 Bytes = 447.6 kB
Load Address: 00800000
Entry Point: 00800000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Linux version 2.6.11-uc0 (LiangYi@ciitec-liangyi) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 1 Thu Feb 23 15:45:58 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 7016k/8192k RAM, 0k/0k ROM (850k kernel code, 206k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
NIOS serial driver version 0.0
ttyS0 (irq = 3) is a builtin NIOS UART
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Microtronix map: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Microtronix development partition definition
Creating 2 MTD partitions on "Microtronix map":
0x00200000-0x00800000 : "romfs"
0x00000000-0x00200000 : "loader/kernel"
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x8f0000 - 0x8fc000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
SIOCSIFADDR=-1: 9
SIOCGIFFLAGS = -1: Bad file descriptor (9)
SIOCADDRT=-1: 9
Unable to create socket
close on exec: : Bad file descriptor
setsockopt: : Function not implemented
Unable to bind server socket: : Function not implemented
Unable to listen to socket
Unable to listen to socket[/b]
--- Quote End ---
I do not know What is wrong?
I use NiosII-IDE to generate vmlinux.bin and romfs.bin and do
--- Quote Start ---
$ gzip -9 vmlinux.bin
$ mkimage -A nios2 -O linux -T kernel -C gzip -a 0x00800000 -e 0x00800000 -n &#39;Linux Kernel Image&#39; -d vmlinux.bin.gz uImage.img
$ bin2flash –flash=U5 –location=0x00050000 –input=uImage.img –output=uImage.flash
$ nios2-flash-programmer –base=0x00800000 –input=uImage.flash –sof=<path to pgm sof>
$ bin2flash --flash=U5 --location=0x00200000 --input=romfs.bin --output=romfs.flash
$ nios2-flash-programmer –base=0x00800000 –input=romfs.flash –sof=<path to pgm sof>[/b]
--- Quote End ---
Then, run bootm and display above. Can someone help me?
BTW, another question. When I use
--- Quote Start ---
$ mkimage -A nios2 -O linux -T filesystem -C none -a 0x00a00000 -e 0x00a00000 -n &#39;romfs&#39; -d romfs.bin romfs.img
$ bin2flash --flash=U5 --location=0x00200000 --input=romfs.img --output=romfs.flash
--- Quote End ---
There display
--- Quote Start ---
uClinux/Nios II
Built 1 zonelists
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b]
--- Quote End ---
I do not know what different between these two method and which is correct for me and how to deal with the problem.
Thank you,
LiangYi
