20 years agouClinux Boot problem
Hi, I am testing my own custom board with EP1C12Q240, Flash=16bit*4M, Sdram=32bit*2M. My system has NiosII/f Core, uart, jtag-uart, sdram, flash, epcs_controller, timer and some PIOs. I use...
20 years agoHi Scott,
<div class='quotetop'>QUOTE </div> --- Quote Start --- Are you using mkimage to create your ramfs.img file?[/b] --- Quote End --- I have tried this before, but display <div class='quotetop'>QUOTE </div> --- Quote Start --- Kernel Panic:......[/b] --- Quote End --- . So, I now do not use mkimage and directly program the romfs.flash(has been transfered from romfs.bin). Then display above I described. Hi hippo, I can not find etc/rc anywhere. Can you tell me where it is in Microtronix Linux directory? Thany you, LiangYi
