20 years agouClinux Boot problem
Hi, I am testing my own custom board with EP1C12Q240, Flash=16bit*4M, Sdram=32bit*2M. My system has NiosII/f Core, uart, jtag-uart, sdram, flash, epcs_controller, timer and some PIOs. I use...
20 years agoHi All,
Does nobody help me? I read the start-up text and find that <div class='quotetop'>QUOTE </div> --- Quote Start --- RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize[/b] --- Quote End --- Here, I do not know why use RAMDISK driver, I also can not find it during Kernel config. Then, display <div class='quotetop'>QUOTE </div> --- Quote Start --- VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 64k freed (0x99c000 - 0x9ab000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1[/b] --- Quote End --- Here, I know romfs has been mounted. But, ramfs.img can not be expanded. So, the boot process can not continue anymore. I do not know why here can not be expanded. Can help me? Thank you, LiangYi
