20 years agouClinux boot from epcs ?
If someone like me wants to run uCLinux on a Nios2 but the fpga must not be a bga type then the biggest fpga available is EP2C20 with QFP 240 pins. That one can be handsoldered http://forum.niosforu...
20 years ago --- Quote Start --- originally posted by smcnutt@Feb 22 2006, 04:43 PM hi michael,
> booting uclinux from epcs. but not the whole uclinux. i think of a smal bootloader
> like lilo (grub under debian) that loads the rest from a compact flash card that
> can't be big enough
you can use u-boot in such a design ... as it supports cf as well as epcs. if your
epcs is large enough, you could fit the entire kernel ... u-boot can load, decompress,
and boot a gzip/bzip kernel image (same goes for cf of course).
currently, i load u-boot from epcs and then boot a gzipped kernel image (~520 kb)
either from parallel flash, a tftp server, or an nfs server. same goes for the cramfs
filesystem (which gets stuffed into sdram as well).
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12890)
--- quote end ---
--- Quote End ---
