20 years agouClinux boot from epcs ?
If someone like me wants to run uCLinux on a Nios2 but the fpga must not be a bga type then the biggest fpga available is EP2C20 with QFP 240 pins. That one can be handsoldered http://forum.niosforu...
20 years agoHi Michael,
> booting uCLinux from epcs. but not the whole uclinux. i think of a smal bootloader > like lilo (grub under debian) that loads the rest from a compact flash card that > can't be big enough You can use u-boot in such a design ... as it supports CF as well as epcs. If your epcs is large enough, you could fit the entire kernel ... u-boot can load, decompress, and boot a gzip/bzip kernel image (same goes for CF of course). Currently, I load u-boot from epcs and then boot a gzipped kernel image (~520 KB) either from parallel flash, a tftp server, or an NFS server. Same goes for the cramfs filesystem (which gets stuffed into SDRAM as well). Regards, --Scott
