20 years agouclinux boot failed !!!
hi all, I am trying to boot uclinux kernel on 2s60es board, I am using build root. I have change memory map (ram and CF still remains same) and removed CF, perf monitor, sysid. While ...
20 years agoBusybox, .config for cross compile
## Build Options#
CONFIG_STATIC=y# CONFIG_BUILD_LIBBUSYBOX is not set# CONFIG_FEATURE_FULL_LIBBUSYBOX is not set# CONFIG_FEATURE_SHARED_BUSYBOX is not set
CONFIG_LFS=y
USING_CROSS_COMPILER=y
CROSS_COMPILER_PREFIX="nios2-linux-uclibc-"
EXTRA_CFLAGS_OPTIONS="-Dfork=vfork -Ddaemon=clone"# CONFIG_BUILD_AT_ONCE is not set
# # Installation Options# # CONFIG_INSTALL_NO_USR is not set
CONFIG_INSTALL_APPLET_SYMLINKS=y# CONFIG_INSTALL_APPLET_HARDLINKS is not set# CONFIG_INSTALL_APPLET_DONT is not set
PREFIX="/home/hippo/rootfs" I used this flags before, (but not now) EXTRA_CFLAGS_OPTIONS="-D__uClinux__ -Dfork=vfork" Busybox, Makefile add elf2flt flag busybox_unstripped: .depend $(LIBBUSYBOX_SONAME) $(BUSYBOX_SRC) $(libraries-y)
$(do_link) $(PROG_CFLAGS) $(PROG_LDFLAGS) $(CFLAGS_COMBINE)
-Wl,-elf2flt="-s 16000" -Wl,-v -Wl,-d
-o $@ -Wl,--start-group
$(APPLETS_DEFINE) $(APPLET_SRC)
$(BUSYBOX_DEFINE) $(BUSYBOX_SRC) $(libraries-y)
$(LDBUSYBOX) $(LIBRARIES)
-Wl,--end-group
busybox: busybox_unstripped
$(Q)cp busybox_unstripped busybox# $(do_strip) There is an important issue about busybox. It takes more memory on MMU-less arch. So I moved away from busybox a little. I use stand alone init, sash, and servers. I built others utils into busybox. see http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
