20 years agouclinux boot failed !!!
hi all, I am trying to boot uclinux kernel on 2s60es board, I am using build root. I have change memory map (ram and CF still remains same) and removed CF, perf monitor, sysid. While ...
20 years ago --- Quote Start --- originally posted by hippo@May 26 2006, 07:27 AM please check wiki, (and help improve it)
http://nioswiki.jot.com/wikihome/operating...ux/nfsfilesytem (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/nfsfilesytem)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15602)
--- quote end ---
--- Quote End --- hi hippo and all, Thanks for the help, also mean while I found the reason why it was happening. Actually I have DMA controller enabled in my hardware design and I did not enabled support for it my kernel configuration. **** menu config **** Processor type and features -> Support of DMA controller with Avalon interface. ******************** After adding this support now my kernel is booting fine with the file system you provided over the web. One more request ... can you share your experience on how you build busy-box for nios system. I have downloaded busybox-1.1.2 and I am building it for nios with your gcc binaries. thanks Ankur
