17 years agouclinux and thriple speed ethernet
Hello. Im trying to get ethernet working on my cyclone3 dev board with uClinux. Im using the sof from the udp offload example at nioswiki.com(http://www.nioswiki.com/exampledesigns/nios2udpoffload...
16 years agoHave you guys tried Altera-TSE(SLS's TSE) rather than atse.c???
I think the example project for the C3 devkit is using Altera-TSE. Change the menuconfig setting to use this Altera-TSE(SLS). Also, if you still see the receive LED blink, but not getting packet right, then check the SG-DMA part, especially, IRQ and descriptor is set correctly. Oh, one more. Not sure which Quartus version you guys are using, but example design was compiled on Q9.0 I believe. You might want to try on 9.0.
