17 years agouclinux and thriple speed ethernet
Hello. Im trying to get ethernet working on my cyclone3 dev board with uClinux. Im using the sof from the udp offload example at nioswiki.com(http://www.nioswiki.com/exampledesigns/nios2udpoffload...
17 years agoYou can try using wireshark on your pc it will tell you if there are any packets from the nios seen by the PC
Try directly connecting the PC to the eval board using a cross over cable it might be the switch
