21 years agouClinux 2.6 Distribution for Nios II vs 1.2
I just downloaded the uClinux installer version 1.2 that claims to support the 1.01 release of NIOSII <div class='quotetop'>QUOTE </div> --- Quote Start --- The v1.2 release is designed to work with Quartus® II 4.0 sp1 on: Windows NT, Windows 2000 and Windows XP. The v1.2 release is designed to work with the v1.01 release of the Altera Nios II Development Kit.[/b] --- Quote End --- When I start the installation I get the error "Could not find Altera NiosII Development Kit 1.0 or 1.01 on this system. Please install and run this setup again." What can I do about it?5 Replies
We're looking into it today and we'll get back to you about it.
when i setup Stand-Alone LWIP,the same occued !
I am currently looking into this problem. I assume you guys have the Nios 1.01 installed on your systems?
I have installed NIOS II 1.0 and SP1.
When I start the NIOS II SDK shell I see: <div class='quotetop'>QUOTE </div> --- Quote Start --- ... Welcome to the Nios II Development Kit Version 1.01, Built Thu Sep 2 00:09:35 PDT 2004 ...[/b] --- Quote End --- What information do you need to locate the problem? - Altera_Forum
The installer is looking for specific registry entries that are set when the Nios 1.01 is installed.
It would be helpful if you could email me a couple of registry dumps of the following registry keys:
To do this, select "Run..." from the start menu and run "regedit". Once in the registry editor, navigate to the paths shown above, right click and export each one to a .reg file. Email the .reg files to [email protected].HKEY_LOCAL_MACHINE\SOFTWARE\Altera Corporation HKEY_LOCAL_MACHINE\SOFTWARE\Cygnus Solutions
