20 years agouClinux 2.6.14 snapshots
v1.0 committed - http://via.dynalias.org/snapshots/linux-2.6.14-1.0.tar.bz2 (http://via.dynalias.org/snapshots/linux-2.6.14-1.0.tar.bz2)
------------------------------------------------------------------------ r920 | jdhar | 2006-04-13 15:51:43 -0400 (Thu, 13 Apr 2006) | 1 line recommitting v1.0 - EPCS MTD, I2C Opencores, Open_Eth, MMC 0.1.5, zImage No CF support yet, I will need a patch for that. So far, kernel seems ok, although a little more prone to page allocation failures than 2.6.12 - if people try out heavy IO operations with this kernel, it will help.5 Replies
hippo, here is what I am seeing - I am doing a simple test where I copy a large file (35M Linux BZ2 kernel) from one MMC partition to another.
In 2.6.12, I can telnet in about 3 different sessions before it crashes. In 2.6.14, I can maybe get only 2 sessions. In 2.6.15, it will bomb as soon as I do anything else. If I have a UART session open, and a telnet session open executing the 'cp' command, and do something like cat /proc/meminfo while the copy is taking place, it gets page allocation failures. So I'm not sure if this is a bug, not enough RAM, or the kernels are getting worse at handling small amounts of RAM. I am going to try and define a more conclusive test, but that's teh current status. - Altera_Forum
I tried this on 2.6.11 as well, and it fails with about 2 telnet sessions as well.
When I check /proc/meminfo, most of it is in 'cached' - I guess because it's doing a large IO transfer. Does this seem normal? - Altera_Forum
--- Quote Start --- originally posted by jdhar@Apr 15 2006, 12:30 AM i tried this on 2.6.11 as well, and it fails with about 2 telnet sessions as well.when i check /proc/meminfo, most of it is in 'cached' - i guess because it's doing a large io transfer. does this seem normal?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14383)
--- quote end ---
--- Quote End --- It is strange. Maybe you can try add a "sync" command to flush write cache before next session. Or use CF drive as a cross check.
I can verify J's 2.6.14 snapshot.
The NIOS serial driver is OK. Unfortunately I couldn't test the LAN91C111 ethernet, since the relevant menuconfig option seems to have disappeared. Any idea what I'm doing wrong? - Altera_Forum
It's not you, I didn't get aorund to porting the other Net drivers; I can't test them out, so it wasn't an immediate port. I will get around to it in a few days and maybe you could try it out http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
