20 years agouClinux 2.6.11 snapshots
I'm starting a thread that will contains updates to the 2.6.11 kernel as they come. I'm doing a lot of driver work in 2.6.11 currently, so there will be peripherals added frequently.
The location of all snapshots are here: http://via.dynalias.org/snapshots/ (http://via.dynalias.org/snapshots/) Current version: 1.5 Features up to and including 1.5: - OpenCores I2C Master Driver - OpenCores 10/100 Ethernet with support for up to 3 MII Ports (can be setup as a router for eg.) - SD/MMC Card support in SPI Mode - EPCS MTD Support - Compress zImage kernel - CompactFlash IDE The SVN Repository is: http://via.dynalias.org/svn/uclinux/ (http://via.dynalias.org/svn/uclinux/) - All the kernels are available there, along with some other stuff. I am not releasing patches for driver work anymore as it is pointless; most people are interested in the complete kernel. - hippos buildroot guide is an excellent read (http://forum.niosforum.com/forum/index.php?showtopic=3174). You can get the kernel by patching as he describes, or just download the snapshot - either should get you to the same place approximately.1 Reply
http://via.dynalias.org/snapshots/linux-2.6.11-1.6.tar.bz2 (http://via.dynalias.org/snapshots/linux-2.6.11-1.6.tar.bz2)
------------------------------------------------------------------------ r909 | jdhar | 2006-04-13 02:08:38 -0400 (Thu, 13 Apr 2006) | 1 line v1.6 - MMC Driver 0.1.4, added mmc_clk module parameter for clock rate (max), driver is now built for mmc_core with built-in status LED (no more PIO port) This will likely be the last release from 2.6.11..
